What is AVEVA Unified Engineering?
AVEVA Unified Engineering is a data-centric engineering environment for capital projects. It integrates conceptual, FEED, and detailed engineering design data into a single hub in the cloud and includes built-in access to AVEVA’s best-in-class engineering and design tools.
With AVEVA Unified Engineering, teams around the world can collaborate on complex projects in real time.
40%
increase in design efficiency at Atkins
30%
reduction in design time at Apply Sørco
16%
of project budget saved at Vista Projects
20%
improvement in IT agility at Veolia Water Technologies
Benefits
Greater engineering efficiency
Integrated engineering, design, and simulation data in cloud-based environment allows for real-time synchronization on complex projects.
Continuous project handover
Project lifecycle data is pulled through the design phases into the operational life of the asset.
Enhanced project sustainability
Design with sustainability in mind, reduce waste, and optimize asset operations.
Features
Hybrid and cloud deployment
Since it runs on AVEVA’s secure common data platform, CONNECT, the solution is suited for hybrid deployments that collect on-premises data and store it in the cloud.
Open and agnostic
The solution allows organizations to bring data in directly from third-party tools and equipment, so they can incorporate the full breadth of project data—no matter how disparate or complex.
Integrated engineering and design
With project data from conceptual, FEED, and engineering design project stages in one data-centric hub, the solution enables project transparency across teams and disciplines.
Digitize compliance
The solution captures detailed data for reporting and tracking KPIs, including sustainability targets, simplifying reporting processes.
Asset life cycle management
The asset life cycle management feature allows organizations to use automated tracking, detailed auditing, and change management to simplify project oversight.
The AVEVA Unified Engineering environment includes
Aker Carbon Capture delivers projects faster
Aker Carbon Capture creates efficient and replicable designs for carbon capture units—reducing engineering hours and the cost of medium-sized offerings by 90%.
How can you use AVEVA Unified Engineering?
Simplify complex capital projects
Unlike a staged, siloed “document-centric” process, AVEVA Unified Engineering allows projects to operate in a data-centric environment—facilitating project transparency and near-real-time synchronization across teams on project status.
Continuous digital design from a single source of truth
The cloud-hosted solution allows for continuous digital handover at the completion of the conceptual, FEED, and detailed design project phases. This creates a data repository which integrates the full breadth of project information.
Create the foundation for a digital twin
When you have the same set of data flowing across your asset’s life cycle, this also lays the foundation for a living digital twin, a digital replica of your asset.
FAQs
AVEVA Flex subscription program is a simple credits-based system that spans any mix of cloud, hybrid, and on-premises solutions across the AVEVA portfolio. You are in control with a pay-as-you-use approach that allows you to easily scale your solution set.
Related products
Formerly Known As AVEVA ERM
AVEVA™ Enterprise Resource Management supports the entire capital project construction design and delivery process with best-in-class 3D model integration, reporting, and visualization to create insights and efficiencies throughout.
AVEVA™ Point Cloud Manager
Formerly Known As AVEVA LFM
Capture the 3D baseline of your existing brownfield asset in a simple, accessible and secure workflow with AVEVA Point Cloud Manager.
